lt4 cam
lt4 cam
Hi guys,as my sig shows I have a lt4 cam kit,in reading other threads,do I figure right ,that changing to a cc306 cam would give my a extra 20 hp approx.just installed 3.73s what a difference from2.73 Thanks for any insight.
Re: lt4 cam
Yea it'd give you the extra 20hp. The problem is with the cc306 cam you'll need about 6500 to get everything out of it. 6200 or so for the hotcam. that extra 300 rpms WILL take its toll on your motor and you WILL need a rebuild shortly. I'd recommend sticking with the hotcam kit, its not a bad kit. Save up for a golen or victory racing motor for 3-4k and then put your cc306 in it and rev it up to the moon!
Re: lt4 cam
The CC306 will also require better valvesprings. IMO, if you've already got the Hot Cam kit, just run it, save your money and enjoy. Will all the bolt-ons, good heads, and a good tune you can make approx. 380rwhp w/ the LT4 Hot cam.
Re: lt4 cam
I put down 320/340 with the HotCam Kit, Mail order tune, Basic Bolt-Ons, and a Built tranny with a 3000 stall.
Its definately not a bad cam. If you're looking for more power -- throw a bottle on it. A 75 wet is more than safe and it'll give you that extra edge you're looking for.
10-31-2016 11:09 AM
95chwagon
01-13-2015 09:19 PM
