LT4 HotCam Dyno Results
#16
Re: LT4 HotCam Dyno Results
Originally Posted by Bersaglieri
It doesnt seem that far off for an A4 with a Hotcam. I'd be loving that TQ. What bolt on's do you have?
-Dustin-
-Dustin-
I don't know, I realize the numbers aren't bad, but I was just expecting a little more, the HP is where I expected, maybe hoping for a little more torque. The converter locked up funny (thats why the spike is there), but the broad curve is what I'm proud of . Hoping to toss on some LE or AI heads with a matched intake manifold and a 75 shot and call it a night.
#18
Those are great numbers. I have been torn on the 224/230 XE vs the hotcam. I still think I am going XE. Did you by any chance have a dyno pull before you put in the cam? Thanks for sharing I am always searching the board for stuff like this and little is ever found.
#19
I agree those are indeed excellent numbers, look at your torque man that equates to a helluva launch, quicker 0-60 which is great off the line, be proud man, it's just the start of the fun go out now
#20
Originally Posted by 96flame
What were the SAE numbers?? These are uncorrected #'s and really can't be compared to anything. Also a graph with RPM is much more usefull than MPH.
The SAE Corrected Numbers were 314/344 @ 65* F and 31% Humidity.
#22
I have pretty much the exact same mods as u except I have a ram air hood with air box and a electric water pump. I just got a hotcam and am going to be putting it in this summer with some 4.10's. Im running a M6. Hope my numbers will be close to that if not better.
#23
jkucz31 - you're probably looking at the same numbers with the hot cam kit, maybe a little more. The setup you'll be running will be basically identical to mine.
97formulakid - as far as cost goes, you can't beat the dollar to power improvement with the hot cam kit.
#25
Originally Posted by Black9TA8
One thing I noticed is that they used the spike to come up with the torque. It looks more like 345 ish ft. lb. to me. They didn't count the spike for hp because it wasn't the highest point, but yet did use it for torque because it was the highest point. Hmmmmmm......
