lt4 intake gasket to heads gap?
need help, installing my lt4 heads and lt4 intake with gms intake gasket #12367777, and noticed there is a slight gap, after torquing down at the base of where the injectors go into the intake,
you can see into the intake ports of the heads,on both sides,
anybody ran into this before, should i be using a different gasket?
any help is appreciated, id like to get the car going this weekend, thanks
We need more info.
The heads look new, but the intake looks old. Was it used? If you bought it used, someone may have it milled wrong. Were the heads worked on or are they brand new?
Did you have the block worked on. Is the deck square?
We need to know what is going on, so we can give you the correct answer.
A little history will help.
its a rebuilt lt1 block to stock specs, no block work done, the heads where recently purchased barely used dont look like they have been worked on, trying to contact seller, intake ive had laying around dont know any history about it but looks stock to me
hard to tell from the pic but it looks like the intake has had the top part of the mating surface milled back on an angle. The gasket surface should be flat from top to bottom. with no angles in it.
If that is the case then I bet it was done like that to try and run an LT4 intake on an LT1 head.
You have only 1 option that I can think of.... pull the intake. You can have them welded up and then milled back down to put the metal back in there.
There should be no gap. That intake will not work with a 7777 gasket. I bet it would be fine with a stock LT1 gasket though.
People mistakenly believe that the LT4 intake flowed more than the LT1 intake and I think a lot of LT4 intakes were hacked up like this so they would fit LT1 heads. What you have there now is a red LT1 intake.
In machining that material off the LT4 intake every potential advantage it HAD over an LT1 intake is gone. All the LT4 intake had was more material above the port to better seal to the TALLER not raised LT4 port. That material also left room to be able to port match to the taller LT4 head ports.
Well the sealing margin is thin when putting an LT1 intake on LT4 heads but it certainly has been done sucessfully.
Ideally though you would use an LT4 intake and use the extra material that was milled off this one to be able port it to better match the intake to the taller head ports.
10-31-2016 11:09 AM
95chwagon
01-13-2015 09:19 PM
