LT4 (not hotcam) question
It's not worth the hassle of putting in there.
LT1 cam(1996 example)
Lift
Intake .447/Exhaust .459
Duration @.050
Intake 205 /Exhaust 207
LT4 cam
Lift
Intake .476/Exhaust .479
Duration @.050
Intake 203 /Exhaust 210
Source- http://www.grandsportregistry.com/lt1vslt4.htm
Lift
Duration @.050
LT4 cam
Lift
Duration @.050
SJS-
He's talking about the LT4 cam. There is a diference between the LT4 cam and LT4 HOTcam. The LT4 cam came in LT4 equipped corvettes and the few LT4 SS's that came from the factory. The LT4 HOTcam was not offered factory on any car.
The specs I quoted above were the LT4 cam, and you are right about the specs on the LT4 HOTcam, 218/228 and .525/.525 lift. As you can see, the HOTcam is quite a bit bigger than the regular LT4 cam.
I have the HOTcam in my car BTW.
Damnnnn......sorry FastnT my bad. It was like 0400 in the morning and I'm on the night shift so I was just flippin through crap. That figures though cause I was like ..."I know Fastn knows his crap so wassap". Now I know.
Sorry again buddy
Sorry again buddy
Originally posted by TA76
Thanks for the info FastZ! I guess I'm better off going with the HotCam.
John
The reason I went with the stock chain is that I have an electric waterpump. With the stock water pump it is spun off of the timing gear. I decided since there was less strain on it because the water pump was electric that I'd be ok with the stock chain. If I was still running the stock water pump I'd probably get the LT4 extreme duty timing set, but to each their own.
John
John
TA76-
AS was stated, no point in the LT4 cam. Go with the Hot Cam Kit and think of going a little further..depending on your cash flow.
For any Cam swap, you have all the front end torn apart so go the extra while your there and replace the old opti with an upgrade.
Replace your opti with a venetd one (ala 95 and a lot cheaper than a non-vented), timing cover, and timing chain. Also a 1LE elbow, Opti harness and vaccum kit for the upgrade to a 95 system.
This setup would dictate an electric water pump as well and the install is not that hard to do if you take your time. The H.C. will run on the stock program, but rich, so to wake the car up, I'd re-program for the H.C.
Again it depends on how much you have to spend, but the total cost is not that bad for what i described above. That is if you do the work yourself...just a thought
Sorry again buddy
Sorry again buddy
FormulaV8
09-01-2002 03:44 PM
Wilson
07-21-2002 05:08 PM
