lt4 springs
lt4 springs
LT4 valve springs are they good enough for the hotcam. I'm going to get 1.66 RR's
what about these Isky 235-D Chrome Silicon Valve Springs, 1.260 OD Single Spring w/ damper, suitable to .550 lift, set of 16 (Special Expires 2/14/2004)
$89.99
Special! $80.99
CRN-10308-1
thanks i might eventuallly get a cam a bit more than then the hotcam
$89.99
Special! $80.99
CRN-10308-1
I have the LT4 Hot springs on now with a stock cam
and 1.6:1 rockers. The springs have worked fine for
me. I would recommend different springs with the
Hot cam and more than 1.6:1 rockers.
I will be putting in the Isky 235-D springs next, but
only because I will not go beyond 0.553" lift in the
future. I think the Isky's would be better than the
GMPP Hot springs just because you have a greater
safety margin. You are looking at 0.545" lift with the
Hot cam and 1.66:1 rockers.
If you use a 0.050" safety margin the Hot springs are
only good for 0.510" lift, why they run them to 0.525"
has always seemed strange to me.
$89.99
Special! $80.99
Does this kit have everthing I need retainters etc? thanks. I would like to be on the safe side with things and get a sufficient spring.
$89.99
Special! $80.99
10-31-2016 11:09 AM
95chwagon
01-13-2015 09:19 PM
