LT4 swap
LT4 swap
what would be involved to swap an actual 1996 LT4 into a 1994 A4 camaro? I spun a bearing and was looking for used motors when i found a complete running LT4 with low milage for cheap
Re: LT4 swap
I responded to a similar question on another forum:
http://www.f-body.com/forum/showthread.php?t=11688
Re: LT4 swap
I forgot about all the accesories on the front of the motor. I knew y f b bodies were all diff there. I was thinking just have a tune for rear 02 delete. And the vent for the opti would have to go somewhere. The accesories should just swap? thanks for the info guys
Re: LT4 swap
Why would you need to "tune" for the rear O2's. You should just use your stock 94 OBD-I PCM and not hook up the rear O2's, crank position sensor, etc. You can't use the C4 PCM.
Re: LT4 swap
Originally Posted by Injuneer
Why would you need to "tune" for the rear O2's. You should just use your stock 94 OBD-I PCM and not hook up the rear O2's, crank position sensor, etc. You can't use the C5 PCM.
People convert both directions between OBDI and OBDII. Ion offers both I->II and II->I conversions on his website.
sleeperZ96BT
09-09-2015 08:28 AM
