LTs or shorties?
#16
I have a dual cat car. I'm gonna get some as&m headers and do the single cat conversion. I should be able to pass the emissions part but not the visual. But i can get away with that. As long as i pass the sniffer.
#17
There is a post in the LS1 section about passing the sniffer without a cat at all. I believe that these cars are efficient enough to run without a cat and pass, but like you said there is a visual part of the inspection. I would hate to see somebody take off one or even both cats and then not pass and then spend the money to put them back on. Another option would be to get a pipe made that eliminates the cats that you could just swap back out when it is time to do the inspection. I'm not sure if they do road side sniffer checks in California because it has been awhile since I've spent more than a week at a time there. 12 more days and I'll be home!
#18
I also forgot to mention that you know that you have have to have the CARB# to pass. Not saying that you don't know this just remember that. But if you know someone like I do that won't do the visual or just doesn't care then you're golden.
#19
thats a bunch of b.s., n.j. state inspectors have no idea what came on your in what year. all they care about is if your car is newer than 72 and that it passes the sniffer test. So back to my question
has any one switched from single to dual cats, and was it a pain in the ***?
#20
