Lucas fuel injectors (42lb)
Hey, anyone heard of these injectors? I am tempted to buy them, but want to hear some feedback. quoting this guy "Lucas High Impedence fuel injectors will flow 42.5 lbs. per hour at 43.5 psi".
anybody know anything about them? They are on sale for 289.00$ and I need 42lb injectors...
I have also seen some ford racing/bosch 42lb injectors for 329.00$ and will buy those if they are better, or if I should save for another company like accel or SVOs? I am not sure which to go so any help is appreciated.
thanks
thanks
Re: Lucas fuel injectors (42lb)
The Buick GN/GNX guys like the Lucas injectors. They are very "fast" and will provide a smooth idle when a huge injector is used. They do have limits on the amount of pressure they will operate at, but unless you're really boosting the fuel pressure way above stock, you shouldn't have a problem.
07-04-2005 05:00 PM
