lunati timing chain crank gear?
i bought a lunati timing chain for my stroker motor and the chain is a bit looser than i would like. does anyone know if it woult be possible to order only a new larger crank gear for this chain? would any single roller gear work with this set? ive done a search for a larger gear only, with no success.
Re: lunati timing chain crank gear?
http://www.moreperformanceinc.com/in...iming%20Chains
Even the stock chain has more slack in it then it shoudl have. Just get one of those gears and be happy with the results. I am about to order one too.
1LEThumper
07-14-2003 12:45 PM
