Lunati timing chain set questions
Hi there
Saw this on ebay but went to summit's website and found this. http://store.summitracing.com/partde...w=1&N=700+150+.
Does anyone use this, and is it complete as in does it need a gear for the waterpump or is it allready there. Can't tell from the photo. I realize the gasket kit is extra, but summit has it for about a hundred dollars less then jegs. Any feedback on this would be appreciated. Mine is stock and has 205k on it, so I believe its time to change it. May not stretch as much as the factory one does. Let me know
tia
andy schuck
tia
andy schuck
I use the Lunati on my builds as well, they're identical to the to original set as far as I can tell.
Works with stock waterpump and timing cover. (also works with EWP)
Note that the set you posted is listed for 92/93 LT1 motors.
I never understood why they don't think it fits a 94.
thanks for the replies. For the price you can't beat it. I was looking for something stock, so a set from gmpartsdirect.com
was slightly more, mostly for shipping as usual. I just didn't want to buy it, then find out I needed to get something else.
thanks again
andy schuck
thanks again
andy schuck
