AS&M 58mm Tb - Offset and Idle ????'s
#31
Re: AS&M 58mm Tb - Offset and Idle ????'s
I think people over estimate the effectiveness of the whole IAC circuit. Split BL's usually come from a cam that's not stock. I had serious split BL problems at idle with my cam. With the stock TB. Enlarged the hole, closed the blades, etc...helped a little but not enough to keep me from running a PE idle.
With the AS&M 58mm TB, it's exactly the same. Unmodified, it acts exactly the same as the unmodified stock one did. With a tiny hole drilled (but not sealed to the cicuit--no tube or anything) it acts exactly the same as the stock one did with an enlarged hole. By exactly the same I mean split BL-wise, IAC count-wise, etc.
From datalogging, you couldn't tell which one is on the engine. So, it isn't exactly a problem for me.
And yes, the bores are offset toward the center of the manifold in relation to stock. You have to open up the holes anyway, you just take a little more off one side than the other.
#32
Jon A: Interesting information. When you bored out, did you remove the whole thing in the middle of the intake (since the AS&M has the AirFoil built onto it)?
#34
I left the stuff in the middle of the intake. I just made the holes big enough for the blades and slapped it on. I didn't see any benefit from removing that stuff. Also, even though the IAC circuit isn't perfectly sealed, the TB still feeds the air there so I'm sure it's still somewhat functional.
#35
Either it functions as oem intended, or it doesn't.
#36
Why would aftermarket not drill the "pass thru" hole in the TB like the stock TB? They made it the way they did for a reason. To me, looking at the stock one, and looking at the AS&M, it looks like the AS&M design makes more sense. I can't see them making a TB that wouldn't "work"...
Not EVERYONE has a problem w/ idle, etc. w/ this TB. I can't see what the deal would be.
#37
Originally Posted by sweetride45
Why would aftermarket not drill...... They made it the way they did for a reason..... I can't see them making a TB that wouldn't "work"...
Originally Posted by arnie
BTW, I personally do not recognize the 58 mm AS&M TB as such. That TB is definately NOT a 58 mm bore TB, and I prefer to call it was it really is...... a 57 mm TB. Those that own one, measure the bores sometime. Also, if any IAC or split BLMs are experienced, it is understandable. That TB was not designed for the LTx series engine.
#39
Why do the other TB's then that ARE for LTx have the same IAC design?
#40
Either it is sealed as per oem, or it isn't.
#41
My point was....is far from perfection in my book.
#42
Read it from the horse's mouth, eh?
http://www.azspeed-marine.com/58mmltthbo.html
"1993-1997 LT1 / L98 / LT4 58mm, 1050 CFM throttle body. Arizona Speed & Marine has stepped up it’s 58 MM throttle valve by CNC machining from a solid block of billet aluminum. Several new features have been incorporated. These throttle bodies are direct bolt-in for the LT-1 engines."
#43
Have you forgotten about my original post already? To save you some time, I've included it here. I've even hi-lited the pertinent area. How do I know this? If I had not obtained this info from the 'horse's mouth', I would not have posted it...how many times in the past? HT really does H.
#44
I just wanted to let you know what I read. If it says it was made for a LTx on their site, one could only believe so. I'm not taking you for an idiot, I'm just showing you my reasoning.
So, if I did the brass tube trick and sealed it directly to the "iac circuit" on the intake, that should correct any problems, right?
#45
If you go to LJ's (Jeff's) site, he will note (and I agree with, as others here have posted) it is NOT a cureall. It WILL however, take a major step in the right direction, to rectify the problem (BLM split). It is a pain in the rectal region, but a worthwhile mod nonetheless. Take care Sweet.
BTW, LJ does not run (what I consider) mild cam timing. Check out the site. It (the site) appears to have taken a respectable amount of time to setup, and periodically update.
