Maf Descreen? Majority Vote Wins!
Old 03-26-2003, 12:51 PM
  #16
Bastardcat's Avatar
MAF=Mass Air Flow.
I think he's just voting in favor of removing the screen.
Bastardcat is offline
Old 03-26-2003, 12:53 PM
  #17
Supermanx500's Avatar
MAF! is a free mod that Smooths out the metal Maf ends. This takes out the metal bars that are in the middle of the ends. Doing this and removing the MAF screen is very very simple....I did this free mod when I was 16 years old......That is how easy it is to do with out messing aything up.
For MAF! go to http://projecttransam.com
Supermanx500 is offline
Old 03-26-2003, 01:02 PM
  #18
mc63's Avatar
I did it and my gas milage dropped. It's stock, so I did not think
( Like Mose Everyone else Here) that it would hurt.
After putting it back in, milage went back up and it drove much better.
Like someone said... Try it, if it works, fine... If not , put it back in!
mc63 is offline
Old 03-26-2003, 01:05 PM
  #19
hairbear21's Avatar
Mass Airflow Sensor, or Mass Air Sensor
hairbear21 is offline
  #20
Mikey97Z's Avatar
NO. It doesn't help. Even the people who posted here who have taken the screen out say they didn't feel any difference ... "but hey, it's FREE" Get a tornado.
Mikey97Z is offline
Old 03-26-2003, 02:11 PM
  #21
Originally posted by snorkelface
Allright, stupid question: What the h*ll is "MAF!?"
It is someone with dyslexia trying to say "!MAF", when they really want to say "!MAF screen". The "!" meaning "without" or "removed". Obviously, you don't want to remove the MAF.
shoebox is offline
Old 03-26-2003, 03:21 PM
  #22
FireAm94's Avatar
I don't think even ws6.com has dynoed it yet so i'm not sure if it helps or not...I can't see it NOT helping....as it unrestricts airflow (as long as you don't damage it during the mod).
Joe
FireAm94 is offline
Old 03-26-2003, 03:32 PM
  #23
Gripenfelter's Avatar
No.
I wouldn't do it because there is the chance you could ruin your idle or develop a stumble.
Gripenfelter is offline
Old 03-26-2003, 05:55 PM
  #24
ZDriver96's Avatar
Yes..
Have had mine out for 2 years. If the car acts funny just put it back in.
ZDriver96 is offline
Old 03-26-2003, 06:23 PM
  #25
Janny's Avatar
I remember a few years back when this was initially proposed as a potential mod. At the time there were some real numbers floating around to indicate how much of a restriction the screen presented. The number was quite high; somewhere in the vicinity of 25-35 % if I recall correctly. I believe these numbers were arrived by testing air flow on a proper flow bench.
In any case, I took mine out years ago. Haven't had any trouble. Can't say what if anything I gained, but aftermarket MAFS are descreened, and well, I'm getting up there in terms of the mods done, so I figure I probably need it by now.
It works. I'm happy
Janny is offline
Old 03-26-2003, 06:29 PM
  #26
sniffin94's Avatar
i took mine out three years ago and have had zero problems
sniffin94 is offline
Old 03-26-2003, 06:33 PM
  #27
Stock Z's Avatar
It has been suggested that the MAF screen is in place to smooth out the air flow going into the engine (making the flow "more laminar" as opposed to a turbulent flow). However, it is important to keep in mind that the PCM is carefully calibrated to measure the air flow into the engine from a MAF that is UNPORTED with the screen. Porting the MAF (and probably descreening to some extent) screws up the calibration, causing the PCM to read an incorrect incomming air flow and therefore calculate an incorrect air/fuel ratio. The O2 sensors are then used to correct the incorrect air/fule ratio. So in the end, porting the MAF should have no effect except wasting time.
With that said, if you are producing high horsepower (like 600+ hp) then the MAF MAY become a restriction.
Another point I would like to make is that ported the MAF will add maybe 1 hp, which is less than a 0.5% increase. (That is a high price per hp if you screw up the MAF or drop your gas mileage, like some have suggested)
All of that rambling for me to say leave the MAF alone, you would be better off spending your time giving your beast a tune-up.
(P.S. I ported and descreened my MAF and recently switched back to unported.)
Stock Z is offline
Old 03-26-2003, 06:48 PM
  #28
fordkiller94's Avatar
ok the results are now:
11 votes to descreen the MAF.
10 votes to leave it alone:
well as of right now it's a toss up....need more votes for a conclusion to this mod...
fordkiller94 is offline
Old 03-26-2003, 06:49 PM
  #29
FastZinTennessee's Avatar
I took mine out, have had no problems. I'd do it again too.
FastZinTennessee is offline
Old 03-26-2003, 06:56 PM
  #30
badass383's Avatar
A complete waste of time. No results what so ever. Don't bother
badass383 is offline
Quick Reply: Maf Descreen? Majority Vote Wins!
