Maf Descreen? Majority Vote Wins!
Old 03-28-2003, 04:51 PM
  #76
Super Moderator
Brent94Z's Avatar
Originally posted by shoebox
I don't see how saying "aftermarket MAFs don't come with screens" proves anything about the need for the screen. GM and everyone else designed their own MAF and I would say GM designed theirs to work with a screen and the others did not.
I've got two aftermarket plastic MAFs without screens. Both have what appear to be the same electronics "arrangement" as the stocker. What I mean is when looking at the Granatelli and then looking at the stocker, it is impossible to tell the Granatelli unit is "calibrated" because it looks identical to the stock sensor. If the design of the sensor at least looked a little different I'd be more inclined to agree with you about this but since they appear physically identical, I'm not so sure
Brent94Z is offline
Old 03-28-2003, 05:22 PM
  #77
94ta383's Avatar
Mir Hussain says:In result you get Lower MPG, Rich Mix, little Less power, Dirty tips, and upset PCM
I concur. Regrdless of how unpopular a name he has. Anyone wanna trade a stock set of ends for my ported/descreened ends?
94ta383 is offline
Old 03-28-2003, 05:32 PM
  #78
Mir Hussain's Avatar
Talking
I have Ported MAF but with Screen
I know my its Kinda make you go
Mir Hussain is offline
Old 03-28-2003, 06:35 PM
  #79
Janny's Avatar
IF the PCM is seeing less air, would it not send in less fuel, making a leaner condition?
Janny is offline
Old 03-28-2003, 08:41 PM
  #80
Dan K's Avatar
Yes. That is why some say they gained horsepower by porting/descreening. They are allowing in "unmetered" air, therefore making the mixture leaner.
The pcm will correct for this at part throttle, but I'm pretty sure it can't at wot.
Dan K is offline
Old 03-28-2003, 09:09 PM
  #81
Arrow
No no
MAF see MORE air, because un channel air.
Then O2 comes out let PCM know; Hey man you running RICH. PCM o ok. Lets cut back some fuel.
Then MAF said What ever O2 saying I dont care. Here is more air so mix it up with more fuel.
in result Richer trim.
Get it ?
Old 03-28-2003, 09:12 PM
  #82
Wrong!
Your PE tables comes from your regular registars (Aka LT trims followed by St tirms)
Old 03-28-2003, 09:43 PM
  #83
anaik's Avatar
I'm wondering why no one has made a comment on my post of gaining 17 g/s. that is equivalent to 18 hp at the wheels. Actually it is between 15 and 17 g/s. If I put the screen back in, I lose the same amount. I've done this back and forth a few times to eliminate a possible error on my Scanmaster.
As O'Reilly would say, what say you.
anaik is offline
Old 03-29-2003, 02:20 AM
  #84
FireAm94's Avatar
A ported MAF will LEAN you not make you run richer. Sorry but you're mistaken.
Joe
FireAm94 is offline
Old 03-29-2003, 02:41 AM
  #85
Dan K's Avatar
Let me try to understand what you just said.
Originally posted by Mir Hussain
No no MAF see MORE air, because un channel air.
How is the MAF sensor seeing MORE air when you said it yourself it is unchanneled/unmetered? That means the extra air that is sneaking through gives you more parts of air per the same amount of fuel.
I don't think so. You said yourself that it is unmetered air. The maf isn't "measuring" correctly because of the porting.
Get it ?
No, I guess I don't.
Wrong!
What? What did you just try to say. I'm not following you at all.
Besides, isn't this where a blm lock comes into play. If you use a blm lock than you have repeatable fueling at wot. O2 input is not used at wot anyways. The computer uses the PE tables...and as long as the blm is locked @ 128...they shouldn't have any effect on your PE. That is the whole point of the lock, isn't it...repeatability? Now I'm off somewhere else...
Maybe I'm wrong on some of the little details...but I'm pretty sure I've got the right idea here.
If you guys want to port and descreen and stuff go ahead...better yet, trade your stock stuff to someone who doesn't want their ported stuff since their car runs poorly with it.
Dan K is offline
Old 03-29-2003, 03:09 AM
  #86
Dan K's Avatar
Originally posted by 2CNTRY
You just like Shanias chestal region.
And you don't?
Dan K is offline
Old 03-29-2003, 04:41 AM
  #87
brokenz's Avatar
Another vote yes. But keep your stock ends just in case. I'm using Whisper ported end that I got on sale from Thunder I think. No problems here.
brokenz is offline
Old 03-29-2003, 07:58 AM
  #88
Perry93TransAm's Avatar
Yeah OK, I admit, her "chestal region" does sawy my vote (along with her posterior)
Perry93TransAm is offline
Old 03-29-2003, 09:28 AM
  #89
xxsaint69x's Avatar
learn from others mistake..do not do it..the computer will REAdJUST AND BUMP UP YOUR BLMS canceling any gains u might notice...the only way to gain anything thru the MAF is thru changing MAF tables with Lt1_Edit
xxsaint69x is offline
Old 03-29-2003, 09:34 AM
  #90
ba96ta's Avatar
Originally posted by Supermanx500
YES!!!!!!! DO MAF! As well.....Preformance onesdon't come with a screen....?.....most of the people that have problms broke one of there sensors.....just don't break the and you wll be fine
Performance ones are calibrated for no screen from the manufacture
ba96ta is offline
Quick Reply: Maf Descreen? Majority Vote Wins!
