MAF Problems
MAF Problems
Posted on this a few days ago but didn't have the code. Went to autozone and had the car scanned. It read a code P0100. Something about a MAF malfunction. What do I need to do. Shoebox said something about checking for a full 12V on the pink wire. Is it that, or does the MAF need complete replacement?
Re: MAF Problems
Didn't think about continuing the thread, was on my way to class. As far as the voltage, I've been at school so I have no way to check it. I just remember you needed the code so I didn't know if you could tell just by checking that or what. I guess that'll be the first thing I do when I get home on Thursday.
Re: MAF Problems
This link contains cuircit tests http://mainstreamtopics.com/forums/i...?showtopic=207
Re: MAF Problems
Checked the voltage in the pink wire just a few minutes ago and it's running full voltage (13.2 to be precise). I guess this means it's not a wire problem and I need to replace it?
formula218
12-02-2014 04:27 PM
