maf sensor
Old 11-04-2009, 10:14 AM
  #16
Didn't the code for the MAF disappear?
There is no way a problem with the MAF will set the codes for the Opti optical sensor.
Injuneer is offline
Old 11-04-2009, 06:13 PM
  #17
remington's Avatar
yes ,
last time I checked with code reader no code for maf
remington is offline
Old 11-05-2009, 05:39 AM
  #18
Guest
Guest47904's Avatar
Considering that it appears to shut down once it goes into closed loop. And it had a code for O2 switching problem. I would unplug one of the O2's and see if it runs better by forcing it to stay in open loop.
If the MAF were the problem, simply unplugging it should show the problem since that will force the PCM into speed/density mode. Assuming of course the MAP is providing a good signal.
Guest47904 is offline
Old 11-05-2009, 07:08 PM
  #19
remington's Avatar
I will unplug maf and see what happens.
Old 11-05-2009, 07:14 PM
  #20
remington's Avatar
car ran the same with no maf sensor Ran for about 10 seconds then started missing and finally stopped after about 20 seconds
Old 11-06-2009, 04:03 PM
  #21
Guest
Guest47904's Avatar
So it would appear the MAF isn't the problem. Now try unplugging an O2
Old 11-07-2009, 10:11 AM
  #22
remington's Avatar
I replaced the one 02 sensor that was showing up on code reader.
I also have a exhaust leak in the manifold. Could this cause the o2 sensor to throw a trouble code?
thanks for the help
Old 11-07-2009, 11:36 AM
  #23
A leak at the exhaust manifold will cause that bank of the engine to run rich. But unless its an extreme leak, its not going to set a "lean" code.
Injuneer is offline
Old 11-07-2009, 12:26 PM
  #24
remington's Avatar
I would say its a small leak. What should happen when I unplug o2 sensor?
Old 11-07-2009, 03:16 PM
  #25
Guest
Guest47904's Avatar
I already answered that question.
SergheiS
07-05-2015 03:27 AM
BigED
06-23-2015 07:19 PM
andrewcapps82
05-19-2015 10:11 PM
pete53
12-09-2014 07:31 AM
Quick Reply: maf sensor
