maf voltage?
maf voltage?
i've read in here that the maf is supposed to have 12v with the key on. well last night i checked the maf,iat,coolant temp sensor, and all three of them have only about 5v? unless i'm using the volt meter wrong, but what could cause them to only have 5v?
well i was checking it wrong, it does have 12 volts, thanks. but i also think i found my problem. there was a fuse blown under the hood, number 10. someone had a 7.5 in it, and i found out its supposed to be a 20, so i replaced it and the car is running great now. idle doesn't hang anymore,stays idling, doesn't smell like gas a whole lot now, other than the normal. the cover on my box is the wrong one, so i called and found out that the number 10 fuse is something called engine sensor?
