Which Magnaflow high flow cat?
http://www.jegs.com/webapp/wcs/store...0251&langId=-1
Which one of those should I be getting? I have no clue what the factory cat is.
Re: Which Magnaflow high flow cat?
I have not had the oppurtunity to reall ydrive the car to see how it performs.
It is a universal, not a direct bolt up so you will need to fab the rear bracket. I made mine out of a steel rod for $2.00
I paid $63.00 shipped to the door from a seller on ebay.
The direct fit cost a lot more and usually includes OEM spec y-pipe.
alex5366
03-08-2015 11:32 AM
jeff94z28
09-11-2002 02:01 PM
