Main studs.?
Re: Main studs.?
Originally Posted by 96ta(nick)
Do i order them for small or large journal 2bolt?
Re: Main studs.?
Originally Posted by 1racerdude
Get the set for a 400 SBC and the tray will bolt back on. Call ARP and they will give ya the correct set number and ya can get them from Summett.
Re: Main studs.?
070-234-5606 SB-Chevy 400ci Main Studs with Hex Nuts, 4-Bolt Main with Windage Tray CartMe! $79.99
Those? I am staying with the 2 bolt mains will those work but just not use all the bolts?
Re: Main studs.?
Originally Posted by MachinistOne
Arp-234-5501
Re: Main studs.?
I would get the studs for large journal 2 bolt mains, without windage tray. Then, i would buy an aftermarket pan, with a built in windage tray, and other nice features like higher oil capacity. Thats just me though, i have heard the factory windage tray is a pretty crappy design from the local engine builders. I believe there is an issue with that part number that machinist gave....because you i think our trays have an extra bolt holding it down, I am not 100% sure, but when I called my engine builder he said something like that.
Re: Main studs.?
Originally Posted by 94zgreenmachine
I'd be skeptical about that number. I bought 234-5601 for a 4- bolt and the windage tray didn't work. You ABSOLUTELY want to keep it.
I didn't say that's the right one to use, just that's the part number for the application that was asked for
Personally - I do what was stated below - Use the standard main stud kit and use an aftermarket pan with built in tray and scraper.
Re: Main studs.?
Personally - I do ......
Re: Main studs.?
What does an aftermarket pan cost?
