major fuel issue with a capital M
Good evening all,
Im hoping someone out there on this forum can be a bit more helpful than some in the trans am forums. I have a 94 Trans Am and of course it has the LT-1 under the hood. I recently dealt with the intake manifold gasket leak and repaired it with a gasket and the rtv seal. I started the car after replacing the intake and it began to blow pure gasoline out somewhere between #5 and #7. I checked the fuel lines and they are snug and not leaking. Obviously it's something I did during the operation as there was no issue like this prior to replacing the gaskets. The injectors all appear to be working correctly. Can anyone out there point me in the right direction??? HELP!!!!!
Here is an exploded view of the fuel rail, courtesy of Shoebox.... Might give some insight..
http://shbox.com/1/fuel_rail_94-97.jpg
well i'm hoping it's not the injector seals since they're new however with the luck this particular car has been giving me anything can be wrong....
....yea, fireballs are cool, you should've seen the one this thing produced
armedtrigger
02-24-2015 08:30 PM
Alex Barnes
01-24-2015 10:21 PM
