Making offical LT1 quickest List; If your fast come on in!
Old 02-19-2004 | 08:48 AM
furely's Avatar
I have the idea to try and see what the quickest LT1's are around. I want to know because I run a 12.5 with just a bolt on LT1, no aftermarket heads, cam, rockers, boost or juice. So I thought I would start a list, below is what I am looking for, if you post a time, speed, and weight and let me know what category you fall under, and your in the top three of your category I will list you. If you do post, please say the category you fall under and your time and speed and weight, (this must be a real time, at a real 1/4 mile track, no calculated times or G-tech times) may have to show a time slip. Also if anyone sees anything that should be changed or a category added please let me know. Just got this idea now, so thought I would try it, I will update it as I get the chances to. Randy
*Category 1: Bolt on LT1 - Stock lower end, heads, cam, rockers, no boost or juice. No weight limit.
-Auto:
-Manual: furely 12.587 @ 108.84 3660
*Category 2: Bolt on LT1 - Stock lower end, heads, cam, no boost or juice, can have aftermarket rockers. No weight limit.
-Auto:
-Manual:
*Category 3: Cammed LT1 - Stock lower end, heads, aftermarket cam and rockers, no boost or juice. No weight limit.
-Auto:
-Manual:
*Category 4: Top End LT1 - Stock Lower end, Aftermarket heads, cam and rockers, no boost or juice. No weight limit.
-Auto:
-Manual:
*Category 5: N/A LT1 - Aftermarket naturally aspirated engine. Includes lower end, heads, cam, rockers, no boost or juice. No weight limit.
-Auto:
-Manual:
*Category 6: Boosted LT1 - Stock low end LT1 engine with boost. Stock Heads, cam. No weight limit.
-Auto:
-Manual:
*Category 7: Juiced LT1 - Stock low end LT1 engine with juice. Stock Heads, cam. No weight limit.
-Auto:
-Manual:
*Category 8: Boosted LT1 - Stock low end LT1 engine with boost. Aftermarket Heads, cam, rockers. No weight limit.
-Auto:
-Manual:
*Category 9: Juiced LT1 - Stock low end LT1 engine with juice. Aftermarket Heads, cam, rockers. No weight limit.
-Auto: Derrick Redd 11.03 @ 125.53
-Manual:
*Category 10: Boosted LT1 - Any LT1 engine with boost. No weight limit.
-Auto:
-Manual:
*Category 11: Juiced LT1 - Any LT1 engine with juice. No weight limit.
-Auto:
-Manual:
*Category 12: Unlimited LT1 - Any LT1 engine with boost and juice and whatever you want. No weight limit.
-Auto:
-Manual:
Old 02-19-2004 | 09:05 AM
Camaro_Maniac63's Avatar
Try www.oklahomaoutlawracing.com/fastlist
Old 02-19-2004 | 09:59 AM
Derrick Redd's Avatar
You forgot stock bottom-end, heads, cam, with nitrous or blower.
Old 02-19-2004 | 01:06 PM
furely's Avatar
Thanks, I added those categories, and I checked out that website. Its nice. I will leave this one up, in case anyone wants to respond.
Old 02-19-2004 | 03:40 PM
RacinLT1's Avatar
bolt on LT1 with LT4 rockers,12.38@109 1.67 60' 3530lbs
Category 7,stock longblock with LT4 rockers, 11.02@124 1.59 60' 3530lbs
Old 02-19-2004 | 04:28 PM
Dragon Racing's Avatar
Catagory #1 12.69 @ 105.89, 3370 race weight
Catagory #2 12.52 @ 107.21, 3370 race weight
Old 02-19-2004 | 04:30 PM
95Bird's Avatar
catagory 5 manual - 10.93 @124.76 1.45 60' 355 with ported stock lt1 castings and solid roller. raceweight 3420
ChrisFrez
01-11-2015 04:47 PM
ChrisFrez
01-04-2015 09:43 AM
ChrisFrez
12-28-2014 03:25 PM
ChrisFrez
12-07-2014 07:01 PM
siguy
11-27-2014 11:07 AM
