making OVC wires BLOWS A**!!!!
i am soooooooo pissed and fed up with this car, and all the "shortcuts" companies make with their parts!! i cant wait to get this car back together... sell it.... and buy a vette and be done with it!!
just bought taylor OVC wires from thunder racing... how the hell are you supposed to crimp anything using those small opti connectors?!?! those things would barely fit 5mm wires!!! forget 8mm!!!! i mean couldnt they have made them a LITTLE bigger?!?! all these little things are adding up ive just about had it!
actual time to remove manifolds & install headers = few hours
time ive spent with these crappy a** taylor wires = ALL NIGHT!
what a waste of money!! if anyone has any tips let me know, otherwise these wires are going in the trash!!!
sorry for the venting but i just feel like and
I agree man they are a BIT@H, me and my brother just put some on my T/A b/c of the Jet HOt LT's, Taylor should have made better wires. Everytime we tried to crimp it, we would have to use our universal crimping tool, and a pair of Visce grips back and forth. And when we finally did get that little silver Piece of SH@t crimped on the wire it wouldn't go up it the boot. So we put some grease around it so it would slide up in the boot, but if it wasn't crimped hard enough the grease would cause it to come apart. Man it took like three hours. Those taylor wires sucked, but what else can you really use when your wanting to get them away from the headers.
Ya wanna know whats easy ?
Put the wire in the boot... Pull it through... The put the crimp on... pull it backwards into the boot. On the 90 degree ends, push the wire in, use needle nose pliers and pull the wire through the bend. The crimp and pull the end back through.
I'll do a write up if you guys want
My brother showed me this after i tried to wrestle these things in after crimping... I felt like a moron
He used hand cleaner too
-Shannon
-Shannon
Originally posted by turbo_Z
ship them to me with $50 and ill do em for ya!
I didn't think they were that bad, the #5 plug with FLP's is far worse. Soapy water, dialectric grease, or even WD40 works well. I think their a little tight so they don't slip around once they are installed, don't think its a shortcut.
We tried squeezing them, wd-40, all purpose oil, everything.
Finally we took a drill (with a bit a little bigger than the hole), and augged it out a little, but the heat from the drill spinning around in it heated up the rubber and made it much easier to work with.
-Shannon
-Shannon
I just lashed all my valves, installed the covers, plugs, and ignition wires in a couple hours tonight actually
Re: making OVC wires BLOWS A**!!!!
Originally posted by Buttercup
I'm sorry, I can't resist laughing at this. You guys are trying to push the crimped terminal into the the boot??? It took me longer to get mark the exact length I wanted than it did to make the wire As Nomad says, grease up the wire, push it through the boot, crimp it, and pull it back. I'm using MSD's but they should be similar to Taylor.
That's what I said!!!
thanks for all the replies. im NOT having problems getting the wire through the boot at all... its just i cant get the thing crimped on!!! the wire doesnt even fit inside the metal opti connector. when i try and crimp it down, the metal thing just digs into the wire and either cuts all the way through it, or slips right off. if the little metal opti conector was a little larger i would have no problem at all.
there would be no need to make your own wires for a C5. the wires are about 5 inches long. i just ordered a set of taylors for my dads car. slow and stock??? buying a stock vette would be just as fast as my hotcam/headers car without ANY effort!!! many people with just intake in the 12's..... ill be lucky with low 13's after doing everything ive done. plus the vette is an all around better car period!
Making the wires for a 'Vette is just as 'hard' Unless you mean you want to keep the 'Vette slow and stock Where's the fun in that?
Check this thread out that I posted a few weeks ago. Might be worth some consideration.
http://web.camaross.com/forums/showt...hreadid=130816
