mallory 685 harness wires not same color
Old 05-10-2008, 12:31 PM
  #16
MichiganSkip's Avatar
Ok give me a minute, I know the green goes to green, red to red. Green is tach signal, and red is 12 volt power from key. the other two are coil + and -. Let me figure out which is which and I'll get back to ya.
MichiganSkip is offline
Old 05-10-2008, 12:42 PM
  #17
OK do you have an ohm meter?
Old 05-10-2008, 12:48 PM
  #18
pyro719's Avatar
yes
pyro719 is offline
Old 05-10-2008, 12:50 PM
  #19
On your mallory harness, what color are the wires on the harness that go into the coil?
Old 05-10-2008, 12:53 PM
  #20
pyro719's Avatar
pink with black stripe, and white
pyro719 is offline
Old 05-10-2008, 01:04 PM
  #21
pyro719's Avatar
ok so green goes to green, red to to red. I have yellow and black left on the box and pink and white on the harness adapter
pyro719 is offline
Old 05-10-2008, 01:05 PM
  #22
OK, I've found what you need but I'll put together something so you see how I found it.
Old 05-10-2008, 01:15 PM
  #23
pyro719's Avatar
You da MAN!
pyro719 is offline
Old 05-10-2008, 01:33 PM
  #24
Looking at this,
http://www.malloryperformance.com/pdf/29068.pdf
and your harness, what colors are the four spade connector wires on your harness that you bought? Are they red,green black and yellow or red green pink and white?
Old 05-10-2008, 01:35 PM
  #25
pyro719's Avatar
pyro719 is offline
Old 05-10-2008, 01:37 PM
  #26
So, just so I keep myself straight,( gonna be 55 in july and I get confused real easy) on the harness, the plug that goes into the coil, are those wires pink and white also? Never mind, you already stated they were pink(with black stripe) and white.
Old 05-10-2008, 01:41 PM
  #27
pyro719's Avatar
wires pluging into car harness are red and green. Wires that plug into the coil are pink and white.
pyro719 is offline
Old 05-10-2008, 01:45 PM
  #28
The white hooks into the black and the pink hooks into the yellow on your box. the red hooks to red and green to green.
Here's how I decided that's how to hook it up.
See page 14 for MSD Orange/Black to Pink/White conversion
The Pink and White wires are the original coil wire colors
http://www.msdignition.com/pdf/6%20series/6series.pdf
MSD to Mallory conversion
(MSD)Red to (MALLORY)Red
(MSD)Black to (MALLORY)Black
(MSD)White to (MALLORY)Green
(MSD)Orange to (MALLORY)Yellow
Go here for a pin-out of the Mallory 29068
We know to hook the Red to Red, and Green to Green
We know from http://www.msdignition.com/pdf/6%20series/6series.pdf page 14 that the MSD Black hooks to the where the white wires WERE on the coil
We know that on the MSD to Mallory conversion thathooks Black to Black Which leaves only the Yellow wire on your Mallory harness
So here’s the revised MSD to Mallory Harness conversion
(MSD)Red to (MALLORY)Red -------(Red)
(MSD)Black to (MALLORY)Black-------(White)
(MSD)White to (MALLORY)Green------(Green)
(MSD)Orange to (MALLORY) Yellow-----(Pink)
Old 05-10-2008, 01:56 PM
  #29
pyro719's Avatar
Thank you very much!
pyro719 is offline
Old 05-11-2008, 10:16 AM
  #30
Did it work for ya?
Quick Reply: mallory 685 harness wires not same color
