mallory 685 harness wires not same color
Old 05-11-2008, 10:34 AM
  #31
Orr89rocz's Avatar
I jsut wired this box on my 89 camaro with external coil. wires were also not the same color but if you just trace the wiring from the coil it should go on easily. Looking at the instructions it says the yellow on the adapter harness is for coil positive. black is coil negative. SO on the adapter harness, the pink with black stripe comes from the coil positive so it goes to the yellow wire. White goes to the black wire to the 685 box.
Glad you figured it out I got to this thread late
Orr89rocz is offline
Old 07-11-2008, 08:59 PM
  #32
pyro719's Avatar
ok so I wired it up like S_WILLIS said to and I have no fire? The box comes on and I can adjust all the features but no start?
pyro719 is offline
Old 07-11-2008, 09:17 PM
  #33
pyro719's Avatar
Whats weird to is the mallory harness will ony plug into the part of the coil where only one wire plugs in from the factory harness. Is this the tach wire?
pyro719 is offline
Old 07-12-2008, 10:15 AM
  #34
pyro719's Avatar
anybody got any thoughts? I bought this thing used so there is a chance its fried? is there a test I can do to makes sure its good?
pyro719 is offline
Old 07-12-2008, 12:59 PM
  #35
pyro719's Avatar
Anyone? This is the last part of the car I need to hook to go race.
pyro719 is offline
Old 07-12-2008, 03:14 PM
  #36
MichiganSkip's Avatar
you could try switching the white and the pink, (but I think it's wired up right now) . and if it still won't fire, you might have a bad box. Did you get the adapter plug to take the box out of the picture? Plug that in and if it fires, you have a bad box. They come with a new box.
MichiganSkip is offline
Old 07-12-2008, 09:04 PM
  #37
pyro719's Avatar
I switched the pink and white wires around but it does the same thing, no spark. I dont have the bypass conector.
pyro719 is offline
Old 07-12-2008, 10:05 PM
  #38
Orr89rocz's Avatar
maybe mallory sells it extra? try getting another box bypass connector
Old 07-13-2008, 12:33 AM
  #39
pyro719's Avatar
I think the box is fried? I have it wired up right but no spark. I think Ill send it off to mallory to get refurbed.
pyro719 is offline
Old 07-13-2008, 11:24 PM
  #40
If you have someone in your area that can make you one using a weatherpack connector to plug into the box, I'd have that done, and plug that in. If the car fires, you know for sure it's the box. I can send you a picture of one if that helps, Or I can make one up for you. I make weatherpack connectors all the time for stuff. It would take a few days for it to get to you though. I believe I told you the right way to wire it, as someone after me told you the same thing I did, so I'd think it is the box, but it wouldn't hurt to try the bypass plug too.
Old 07-14-2008, 06:23 AM
  #41
Orr89rocz's Avatar
i think mallory will refurbish it for somewhat cheap. new they are 249 or something like that, but they will rebuild them for i think 60-70 bucks but i dont remember what i was told
Old 07-17-2008, 12:12 PM
  #42
01Z
01Z's Avatar
In case you are still working on this, I had the same problem and it turned out that I had barely touched one hot wire to the chassis of the Hyfire while I was wiring in a LED to show when the box was powered up. The Hyfire would function and the car would crank but it would not fire once. I went under the hood, found the ignition fuse and saw that it had blown.
01Z is offline
Old 07-17-2008, 01:38 PM
  #43
pyro719's Avatar
I cut the weather pack connector off my box because I didnt have the harness for it had to make my own. I wish this thing would work. Ill try calling mallory to see if they will refurb it.
pyro719 is offline
Jubjub
03-19-2015 10:23 AM
jayvar
02-02-2015 10:00 PM
01-23-2015 01:13 PM
siguy
11-27-2014 10:07 AM
gh0st
09-01-2002 10:24 AM
Quick Reply: mallory 685 harness wires not same color
