MANELY GUIDEPLATES on LT1 ?????
#16
Where do you pick up the Trick Flows at? I dont see em on Jegs's website. What about these guideplates? Are thay any good? http://www.jegs.com/webapp/wcs/store...47134_-1_10227 Part #11650-1, using them with my stock pushrods, motors from a 94, so they are hardened.
#17
I'm confused here. A few years ago, we were told the ONLY guide plates we could use on an LT1 were the GMPP plates, or Isky adjustables. This was because the valve spacing is different on an LT1 than a standard SBC????
I know I've tried COMP plates for a standard SBC, and the rockers roller tips wouldn't even line up on the valves. Are these Manleys or Trick Flows specifically for an LT1?
Frank
CPT
Frank
CPT
#18
Probably for Bowtie SBC heads which have a very similar spacing. (Maybe Vortec also??) Only way I have seen to get them PERFECT is with Isky's, and the only way to run 3/8ths PRs is with Isky's.
BTW wonder why nobody is jumping on GM's nuts about the bad guideplates like say the Comp R and 26918 deals? Like the guideplates, the only thing you can do is just move on to another better part.
Bret
Bret
#19
Bret
Bret
#20
#22
#23
I just swapped out a set of GMPP guideplates that probably missed the hardening
step and they had significant wear after only 5k miles. The GMPP guideplates
that went in where hardened. I checked each one with my auto center punch and
the dimple was about 1/3 the depth as the non-hardened ones. I can't believe that
GM has not done squat about the crappy guideplates.
