Manifold Gasket Recommendations
I have to replace the gasket at the flange connecting the driver's side manifold and the cat. Any alternatives to the stock replacement? Is it worth the trouble going aftermarket?
I never had problems with mine leaking when I had the stock manifolds but I read some people used a new stock gasket plus some ultra copper sealant. Not sure if there are any alternative gaskets available, you might find some info on a search on "gasket leak" or something like that.
