march pulleys
Re: march pulleys
I installed mine on my 97SS and it wasn't a press fit. Did require an impact wrench to get the nut off and back on, since the pulley would turn whenever I tried to undo the nut.
I can't remember, but isn't there a key holding the pulley in place? So when you say it doesn't fit, you may have to line it up very carefully and gently tap in on with a piece of wood and mallet. But then again, if the pulley is smaller than the shaft, it is obviously not going to fit no matter what.
My guess is, you just need to give it a bit of help.JMHO
sleeperZ96BT
09-09-2015 08:28 AM
