Maybe you guy's can help me with my little ford ranger ?
Every time I stop at a light , stop sign ect.. my truck wants to over heat . It's a 88 ford ranger v6 . I noticed some coolant on the ground and noticed that the radiator has two very small leaks on both side corners at the very bottom . is this the reason it's overheating only at a stop , and can I add something to the radiator to stop the leaks . Ialso figure that it could be the fan clutch , but the fan seems to be moving fine . Any help is appreciated .
Ben
Ben
It can't be leaking if you expect it to cool properly. Take the radiator to a shop to have it repaired if it is leaking. Then if you think you have a fan clutch problem, replace that next.
Gee, I'm giving advice on Fords, now.
NewsBot
12-03-2014 12:30 PM
bossco
11-29-2014 10:18 AM
LT1runner
33
07-24-2002 01:19 PM
