Measurements of optispark
can someone take a couple measurements for me? (if you happen to have an opti laying around )
1. Radius (or diameter, either one) of the disc with the 360 slots
2. distance from the center of the shaft to one of the outside corners of the optical sensor
3. thickness of the optical sensor
thanks alot! later!
jeremy
thanks alot! later!
jeremy
