melling M55 Oil pump Question!!!
Old 02-19-2006, 12:46 PM
LUDA0840's Avatar
Exclamation melling M55 Oil pump Question!!!
Will I be ok with the stock pump? Or should I go with a High Volume? My mods are in my sig. Thanks
LUDA0840 is offline
Old 02-19-2006, 01:04 PM
LT1inaMGB's Avatar
Re: melling M55 Oil pump Question!!!
Do a search on High volume oil pump and you will be reading for days.
LT1inaMGB is offline
Old 02-19-2006, 01:39 PM
turbo_Z's Avatar
Or if you dont want to read for days the basic idea here is the high volume pump has the potential of running the stock oil pan dry. You are better off staying with stock or if you want to, get the high pressure spring and put it in the stock pump.
turbo_Z is offline
Old 02-19-2006, 01:59 PM
FastZinTennessee's Avatar
I put a stock style melling pump in my car during the build. It's been discussed that the high volume pump will require more power to turn, and it can possibly run the pan dry after extended high RPM use.
FastZinTennessee is offline
Old 02-19-2006, 02:00 PM
LUDA0840's Avatar
where do I get the spring?
LUDA0840 is offline
Old 02-19-2006, 02:01 PM
turbo_Z's Avatar
I got mine from GM. Youll have to use the search function if you want the part number... GM white oil pump spring.
turbo_Z is offline
Old 02-19-2006, 03:48 PM
SStrokerAce's Avatar
Actually a Melling M-55A will work for you perfectly.
M55A
This is the pump I recomend. I start with this or a stock pump and work them over.
Bret
SStrokerAce is offline
Old 02-19-2006, 04:56 PM
firebirdStud's Avatar
which pump bret? There is 700 listed... lol.
firebirdStud is offline
Old 02-19-2006, 05:16 PM
Mindgame's Avatar
Originally Posted by SStrokerAce
a Melling M-55A
Bret
-Mindgame
Mindgame is offline
Old 02-19-2006, 05:33 PM
Thanks MG. lol
damnit I wish I could read! :-)
Old 02-19-2006, 05:35 PM
I was almost going to say reading is fundemental... GO JOE!
which pickup do you use?
Old 02-19-2006, 05:38 PM
Depends on the pan.
Old 02-19-2006, 05:50 PM
well, for a stocker or a milden or moroso?
Quick Reply: melling M55 Oil pump Question!!!
