melling M55 Oil pump Question!!!
#18
Re: melling M55 Oil pump Question!!!
Originally Posted by firebirdStud
ok fair enough. Just wanted to make sure I got the right pickup for the pan, but it sounds like there are too many to start listing. thanks sstrokerace.
Call your pan manufacturer and they will have a pickup to go with the pan,that's the BEST one.
#22
O yea? Crap!! I bought the melling m55 at autozone. And gonna buy the spring tomorrow at gm. I wouldnt want to run a High Volume pump again, I ran the melling Hv pump before and crapped out my engine, and I wouldnt want that again. Thanks to all for your input!!!
#24
so that pump would take the abuse of everyday driving, and the shock of hard revs and extended use in a 383 stroker pushing 450 rwhp? If so, I'm sold!
#26
Originally Posted by Masnart39
The M55 series pumps are 5/8" inlet
The M155 series are 3/4" inlet
You need a Canton part # 20-020 pick-up for the 5/8 inlet.
#27
SOOO this is the first I have heard of using a stock volume HIGH PRESSURE pump. What is the pressure when you use the m55 pump? I guess the point of stock volume is so it DOESNT suck the pan dry???
*parts list
- m55 pump with a 5/8 inlet
-canton pickup #20-020 for the 5/8 inlet
Thanks !!! ---
*parts list
Thanks !!! ---
