Missfires
Give us a little more info.
Is this at low/high rpms?
Occurs at idle?
Change anything on the car before it started doing this?
Has it rained or did you wash the engine bay?
How do the old plugs look?
See any wires arcing at night?
Is this when the motor is cold or warm? Or at all times?
What exactly makes you think its a misfire and not a fuel problem?
Occurs at idle?
Its throwing the P0300 code at me which is missfire.
occurs all the time
nothing changed
it was raining the day it started, BUT, it did it after i had shut the car off and started to missfire when i turned it back on
occurs all the time
nothing changed
since thursday, i checked the boots and didnt see anything, i checked the EGR valve, and tomorrow i'm gunna try to swap a few of the wires with some new ones to see if i can figure it out to wires or the opti. You thinking opti?
Im thinking opti... you bet man. After a rain and the car starts acting weird you can almost guarantee its the opti. How many miles on this opti? Yours is vented but that doesn't make it safe from liquids. Try swapping the plugs and the wires and see what happens. It's cheaper than a new opti.
yea, wires are definately cheaper, i've got 80 or 81k on the car, original opti. But one thing that almost doesnt make me think opti is that it only did it after i got back into the car and started it after it sat for 5-10 minutes, its not like i drove through a puddle and 5 seconds later the light went on.
like I said above. if its the left bank, and your car isnt batch fire, check the 02s. Run the o2 tables see what you get. My car was missing terribly, and I found my o2 wire was shorted. I thought as well as everyone else that it was my opti. Opti is like god in this forum. if something we dont understand is wrong, we just say the opti did it
eds96ragtop
03-05-2004 04:43 PM
MattysTA
02-07-2004 12:20 PM
