missing and bad power loss issues
its a 94 z28 a4 just replaced the opti with a new gm opti the car has 131xxx on the clock . the opti fixed one problem i had now theres another one . the car runs alright when i first start it in the morning while cold adn the warmer it gets the worse it gets . ive done the icm mod checked plug wires the o2s are new also. im running out of things to check here any one have any ideas i mean i can floor the car and its like bluhhh it just dont do anything i barely has the power to do the speed limit while its at running tempature any suggestions
would a bad opti cause it to miss? i have a 96 z28 with the lt1. the plugs and wires are all new. i put a new opti in it about 2 months ago. ran awesome for about an hour after opti was kinstalled and after that it car started to miss. check engine light is on so i hooked it to a scanner. cylinder 3 is about dead. more misfires than fires. and cylinder 6 has a few misfires but not many
10-31-2016 11:09 AM
armedtrigger
02-24-2015 08:30 PM
