most ci out of .030
Re: most ci out of .030
Originally Posted by Jason Short
You can get 409ci with a 4" stroke/.030" over on an LT1. That is the max ci. without going to a custom (read: expensive) crank.
Jason
Jason
Originally Posted by My Iroc Z28
well not only that but i doubt that a 409 will be streetable because of the stroke and driveability...
This has been rehashed here many times. Yes, as Jason indicated a 409 can be built. And as he also stated, even larger small blocks can be built. But most people think that the largest practical stroke, in terms of cost effectiveness, is a 3.875" (396). A 4" crank in an LT1 is definitely not "plug-n-play". Such a motor will make a lot of torque, for sure. But hp and revs will be limited by the available valve size (determined by the bore) and mechanical considerations. You'd be farther ahead to put the money in to the heads (pun intended), induction, valvetrain, and exhaust systems and build a 383 or 396.
Rich
Rich
