Most powerful cam?
Re: Most powerful cam?
Originally Posted by frankthetank078
what is the biggest cam you can put into an engine with stock heads? by biggest i also mean which gives you the biggest gain
Did you change your mind?
It depends on what you mean by "biggest gain". If you are looking at area under the torque curve (in the rev range you will run the engine) which should give you best acceleration, the optimum cam won't be very "big".
It might be fairly close to what you had in mind in your signature.
you can jam a 24X/24X 110 LSA cam in there and it would be big, but stock heads are going to choke it off so bad, you'll never see the power.
With stock heads, I wouldn't really go anything above a 22X/22X duration and a 112LSA at the most. Anything bigger is going to be useless unless you have the airflow from the heads to back it up.
People have cc306's and gm 847's in motors with stock heads. They usually lay down 340-355 rwhp and similar torque numbers, depending on the trans and the rest of the setup. Those are the biggest cams as far a duration and lift go that I have read about on this site. As mentioned before the stock heads are going to choke the cams i talked about. Get the le1 setup you have in your sig. or get the le1 heads and a le2 cam. The potential for the motor lies the heads. You can only throw in so much cam. good luck
oo ok i thought the heads would cut alot of the power from the cam but what about getting different heads and leaving the same cam.. would that choke it more considering the heads wouldnt be getting the most amount of air and fuel
Steve
10-31-2016 11:09 AM
