Motor dies and then refires while driving
I bought a 95 and have started driving it recently. Sometimes while im driving the motor will start to cut out. It feels like someone keeps turning the key on and off while im driving. A few. Times even cometely shutting off. When i try to restart it wont even try. But if i wait maybe 30 seconds and try while holding the throttle wide open it fires again . Bad opti or fuel pump?
Doing what I like and not what I should!
Re: Motor dies and then refires while driving
Yes it does crank. Checked fuel pressure today and it 40 psi key on. And 36 psi while running under load. As of right now im sitting on the side of the road.
Its got spark too. Im going to get a coil and try it. And a fuel filter too. It will start if i hold the throttle wide open but shut off almost immediately. How do i check my regulator. Seems as tho i have plenty of fuel pressure, because it smokes black when it does finally start
Pull the vacuum compensation line off the fuel pressure regulator, and look for wet fuel in the line. Put a fuel pressure gauge on the Schrader valve and check for incorrect fuel pressure.
Ok so... I put a new coil on tonight. The car started but still has a bad dead misfire in all cylinders at random times while driving.
Checking fuel pressure again. I have 35-36 at idle and about 40 wide open throttle. When unhooking vacuum to the regulator i get a steady 40 psi idling and wot.
What is the electronic piece that is bolted together with coil? I suppose it is some ignition component? Can it fail?
You really need to familiarize yourself with Shoebox's website - it is the best source on the Internet for LT1 information.
http://shbox.com/1/4th_gen_tech1.html
The coil is attached to the ignition control module. The ICM is bolted to the driver's side head. It has a tendency to heat soak, and can cause misfire problems. Rob/Shoebox has a suggestion on spacing the ICM away from the head to mimimize the heat soak.
Alex Barnes
01-24-2015 10:21 PM
Oncomingstorm22
01-22-2015 07:15 PM
