Motor mounts
Old 07-09-2005, 12:16 AM
  #16
3gc
3gc's Avatar
Re: Motor mounts
It looks like with one side it uses a regular gm clamshell mount so you'd have to remove the rivets and use the factory casing. Maybe that's what they meant.
3gc is offline
Old 07-09-2005, 01:16 AM
  #17
FIREHAWK #7's Avatar
Re: Motor mounts
yeah when you do the motor mounts... youre gonna have to drill out the rivets on each "clam shell" motor mount...takes less than 5 minutes to do em..... then you just stuff the new poly. motor mounts in there and get er done....
FIREHAWK #7 is offline
Old 07-09-2005, 01:27 AM
  #18
bdc95ta's Avatar
Re: Motor mounts
IF you have the right drill bits it only takes 5 minutes took me over an hour!!!
-b
bdc95ta is offline
Old 07-09-2005, 01:48 AM
  #19
Re: Motor mounts
damn man.... sorrry to hear that..... lol
Old 07-09-2005, 03:33 PM
  #20
3gc
3gc's Avatar
Re: Motor mounts
As usual you guys were right. I was under the car today replacing the LCAs and put a jack underneath the transmission and jacked it up a bit. The Transmission mount is seperated on one side. Is it important to use the same type of engine and transmission mounts? I figure i'll go with the energy suspension motor mounts and go with the GM trans mount because i don't want the extra added vibration.
3gc is offline
Old 07-09-2005, 04:45 PM
  #21
LT1 POWR's Avatar
Re: Motor mounts
So I can find both the motor and transmission mounts on summit.
LT1 POWR is offline
Old 07-09-2005, 05:42 PM
  #22
Re: Motor mounts
or www.thunderracing.com Like to use them more..... they're fast, and know there $HIT!!!
Old 08-06-2006, 03:45 PM
  #23
jonota's Avatar
Re: Motor mounts
You don't have to have the same type but I will tell you this: I went through 4 stock transmission mounts AND a 1LE before I got an ES poly mount. Had the ES mount for 3 and a half years or so, no breaks and NO vibrations.
Jonota
jonota is offline
Old 08-06-2006, 04:31 PM
  #24
LT1_383's Avatar
Re: Motor mounts
This is an old post, but 3gc was my old user name. I got rid of my website and couldn't get my email anymore so i had to make a new user name. I've had the GM mount with the energy suspension engine mounts for about 10k miles yet, no signs of the trans mount going out. I wasn't pleased with the ES engine mounts though. The vibration wasn't bad but over the last year the mounts seem to have shrunk in the clamshell. They can actually move around in there. I'm going to put GM mounts in soon.
LT1_383 is offline
Old 08-06-2006, 05:24 PM
  #25
jonota's Avatar
Re: Motor mounts
LOL.. I'm an avid search function user... I rarely post my own questions as if I search hard enough I can usually find the information I'm looking for. Then I can post any little tidbits that I can't find or figure out myself. Unfortunately that means I run across old posts and I'm too scatterbrained to realize it!!!
Jonota
jonota is offline
HectorM52
07-30-2017 11:46 AM
Rde Bandit
03-21-2015 10:17 PM
DirtyDaveW
03-15-2015 07:01 PM
silvermansteve
03-04-2015 05:02 PM
Nostang 96z
08-31-2002 12:01 PM
Quick Reply: Motor mounts
