My 1994 chevy camaro is having throttle body issues
Old 06-25-2009 | 12:35 AM
TRAVB20's Avatar
Question My 1994 chevy camaro is having throttle body issues
I have a 1994 chevy camaro 5.7l an i justy ordered a 52mm throttle body. I installed it an my car continously boggles out an cutts off. I believe my mass air flow sensor has somthing to do wit it. Getting too much air or sumthing.. What should i do?
Old 06-25-2009 | 12:43 AM
TRAVB20's Avatar
Question Why isnt my 52mm trottle body working properly?
Just purchased a 52mm trottle body for my 1994 z28 camaro an i installed it but it boggles out an continusly cuts off. Am i getting too much air? If so how can i ajust it?
Old 06-25-2009 | 01:40 AM
Hal Fisher's Avatar
Did you set the sensor correctly (forgot what the heck the name is)? You have to turn it to get the right closed voltage (.6 to over 4.5 but I'm doing this all by memory).
Hal
Old 06-25-2009 | 05:31 AM
Check the rubber intake elbow and make sure you didn't tear it or fold the bottom under when you tired to push it over the throttle body. Make sure you reinstalled the MAF sensor correctly, and didn't damage any pins on the connector. Make sure you tightened the bottom plate on the throttle body correctly when you swapped it over, and that you used a good gasket between the TB and the intake manifold.
Old 06-25-2009 | 05:34 AM
Just post a topic once - not twice. I'll merge the threads.
Red Hawk 94
03-18-2019 04:03 PM
CARiD
12-26-2014 04:20 AM
Queens94z28
12-20-2014 09:11 PM
thenewkid
11-27-2014 09:41 AM
07-04-2005 05:00 PM
Quick Reply: My 1994 chevy camaro is having throttle body issues
