My 383 @ idle w/ 3" True Dual + H-pipe + (2) Dynomax bullets video
Hey guys thought I would finally post a video of what my new 383 sounds like. Originally I had Jet Hot Long tubes w/ jet hot y-pipe to an slp loudmouth....had that setup since 2000 and moved it over to my 383...didn't like it that much.....I now went with the same jet hot long tubes.....true dual 3" exhaust off each collector with a jegs universal h-pipe to (2) Dynomax bullet mufflers dumped before the rear and turned down away from the car.
In the video you will also see my new Moser 12 bolt rear, full red chromoly rear Spohn suspension w/ all adjustable with spherical rod ends and QA1 rear shocks.
Type of heads & cam in the sig if you're wondering. What do you guys think?
http://www.youtube.com/watch?v=Pmzqu03ZgJ8
