My Camaro don't start the engine
Old 12-11-2008 | 12:08 PM
wolfrider's Avatar
I have a 1993 Camaro Z-28, and I was running it a few days ago and the motor stop functioning when I was running. I was thinking it could be the coil or the fuel pump. There's any way to verify the car with the OBDI with out the scanner, or anyone could help me with this???? Thanks a lot
Old 12-11-2008 | 03:43 PM
93transam1234's Avatar
First thing you need to do is test if it is getting spark at the coil and at the plugs, then what the fuel pressure is.
Do a search for pulling codes on OBDI, you can do it with out a scanner.
Old 12-11-2008 | 07:43 PM
wolfrider's Avatar
I use a digital meter but I don't know how to get the codes.
Old 12-11-2008 | 10:25 PM
Since you have a 93, you can flash the codes on the SES light, by shorting the pins in the ALDL connector. Shoebox has a guide:
http://shbox.com/1/dlc2.jpg
Old 12-12-2008 | 11:06 AM
wolfrider's Avatar
ChrisFrez
12-07-2014 06:01 PM
globalprojeff
12-06-2014 04:18 PM
siguy
11-27-2014 10:07 AM
ChrisFrez
11-23-2014 10:33 AM
07-04-2005 05:00 PM
Quick Reply: My Camaro don't start the engine
