my car is runnin like ****
ok my car started missing and **** so i changed the plugs its still doing it the best way i can descibe it is if i put it in like 5th gera around 40-50mph and floor it , it kinda sounds like popcorn in the microwave the other night i think i went through my revlimiter on spray so i dont know if i bent a valve or broke a spring let me know what u guys think it might be my opti
Originally posted by JOE96Z28SS
I see this is'nt good enough for the "Chosen Ones" in advanced tech because their SO ABOVE that! how's your Oil Pressure???also have you taken a compression test?
As far as the problem. Lets have some more details-
Does this happen while stopped and reving?
Does this only happen at a certain rpm?
Have you checked your wires recently?
Do you have any or can you get a log of the problem?
happens all the time but mainly u can hear it under heavy load, not at any certain rpm, wires are new
but i kinda noticed tonight it kinda sounds like a header leak would this give me a loss in power ? im not sure if it is though?
If you hit the rev limiter on spray there is a good chance you have some piston damage if you have stock pistons. Open your oil fill cap while running and see if you have alot of fumes coming out....If you are getting kinda a popping\puffing noise when you floor it its most likely a blowby from a broken ringland. At any rate check your compression and that will tell you for sure.
1996LT1Z28
Middle Atlantic
12-04-2014 09:37 PM
1996LT1Z28
12-04-2014 09:20 PM
