My complete LE2 H/C swap list (I hope, lol)
#19
The freeze plug in the kit is to block the back of the water pump, not the timing cover where the drive used to be.
Yes get head bolts as the factory ones are torque to yeild bolts and can only be torqued once. You can get factory replacements from O'Reilly's or ARP bolts/studs depending on what you want to do. Also Iw ould look at bigger injectors than 30, probably 36, IMO.
10-31-2016 11:09 AM
