My girl calls it snap crackle and pop
Every since I installed the Hypertech 160 thermostat and when I slow down worse if I do it manually with the auto but it snap crackle and pop lighty. Car runs at 165-175 F. Guessing tune?
the connections you removed.
Mine sometimes does this, i'm sure its the exhaust, but i could be wrong, i'm also running the hypertech & 160* stat, but it did it with the 180* stat also.
Don't know where to start here....
The SLP loudmouth backfires like that...Just quit shifting down so much especially at high rpms, and you'll never hear it make that noise.
After I put my longtubes and true dual setup on, I expirenced the same thing you're describing.
More or less its the exhaust system. My car when stock did this ever so slightly if you let of from WOT. But with out the cat and freer flowing mufflers its more apparent.
It's a pretty common thing to expirence when you change exhaust systems I've been told. I've learned to drive my car so that doesn't happen anymore.
Hope something in there helps.
~Jim~
~Jim~
