My LE1 1/4 times ..
#16
Re: My LE1 1/4 times ..
Something is definitely not right. Maybe you just can't drive. Just playing, yeah hit a dyno and see what it does. I'm running le1 heads but with rev 2.0/1.56 valves and a custom Joe cam thats smaller than the le1 cam. Even with being an auto and with just a base tune my car trapped 111.11, then after a better tune(from data logging it and pcmforless) the very next week it went 114 mph. I'm sure my car has some 118+mph traps in it when better weather comes along. See sig for mods/times as a comparision. My time was with a 1.65 60ft.
#18
Originally Posted by jcolez28
I thought the 1LE heads had stock valves? I thought the difference in 1LE and 2LE heads was the larger valves? Thanks
#19
So 1982z28, So would you say that your heads are closer to the LE1 or LE2 combo? I have been thinking about doing something similiar. I want the LE2 heads but with a small cam like the LE1 or smaller. The one guy on here that had that combo did something to his motor now he is going with a 383. He didn't get a chance to dyno it before it his motor messed up.
#20
his times look an awful lot like mine, i bet you are running your stock gears?? If you are, i bet that is that main thing holding you back. Stock gears and a high end cam are a terrible combo. Just my $.02. Also, how does your clutch feel, maybe she is slipping a little bit on ya??
trav
trav
#21
Those times do seem a bit slow for what you have done. Have you scaned it for codes?
#23
www.advancedinduction.com
110 mph is around 360rwhp on an F-body w/o much weight reduction. I wouldn't expect to pick up 50 rwhp on a dyno tune, but hopefully you'll prove me wrong
Mike
Mike
#24
Mike
Mike
Just for reference - all full weight vehicles. mine is a lightweight though 3500lbs with me (minus jack and spare though).
#25
Originally Posted by RealQuick
I was making 368rwhp/336rwtq when I ran consistent 114mph. I know a few local LS1 guys that trap 111-112mph with 335-340rwhp.
I'm talking about 3600+ lbs cars w/o driver (no weight reduction LT1s)
Hell, my Z was 3870 w/driver, but it was a vert and went 114, but it was over 400 rwhp. When I sold it, I opened it up a little and it was more like 440rwhp
Mike
#26
Your car is a lightweight and those other cars are LS1s (lighter)
Mike
Mike
#27
Those LS1's arent light. Another example is a guy i know with a 430rwhp heads/cam LS1Firehawk said his race weight was 3750lbs and he ran 120mph traps with M6.
It was common knowlege that when the LS1 debuted in the F-body in 1998, the aluminum block shed around 100 lbs off the weight of the car, bringing the Z28 closer to 3300 lbs w/o driver.
That guy probably has audio stuff in his car and extras that weigh it down.
Mike
#28
Wrong.
Mike
Mike
#29
ya stock 3:42 gears, with 4:10s at like 115 mph is that still 4th gear? i don't want to hi 5th gear in the 1/4.
my dad has a scanner and we're going to log a run here in the next day or two, and i'll post and then maybe that will help out.
#30
Wrong.
Here is the curb weight for my car (3390 according to the site and i got 3340 withou spare and jack). I also had the extra weight of 17" rims and 275/40-17's versus my stock 16" rims and 245/50-16's. Go to bottom of page.
http://www.f-body.org/tech/tech.htm#95weights
and
http://www.intellichoice.com/reports...86/section/all
02 SS this link says 3411 lbs. Similar weights.
http://supercarx.com/articles/specifications/camaro.htm
This site also states 3411 for LS1 Z28
http://www.car-buying-strategies.com...imensions.html
1998 Pontiac Firebird Formula checked in at 3,345 lbs and 2002 Chevy Camaro Z28 is 3,439 lbs
http://neptune.spacebears.com/opine/safety.html
This article says that a 99SS weighs 3439
http://www.edmunds.com/reviews/compa...3/page009.html
As you can see, that just because they shed 100lbs off the engine block, they made up for it elsehwere according to these specs. Thanks for telling me I was wrong though Like I stated before, the ls1's trapped the mph and I trapped my mph and were on pace with each other. The ls1's that had 20-30rwhp less than me trapped 2-3mph less than me. If our cars werent similar in weight that wouldnt happen. i am sure vehicle weights differ, but here were a few examples that show LS1's not lighter then LT1's. they are infact very similar despite change in the engine block.
