My LT1 dyno results...Not too shabby, I think.
Just got back from the Superflo chassis dyno today. I made 3 runs with closed Borla (all thru the muffler) and three runs wide open Borla (full cutout).
I had slightly better results using full muffler.
My 1995 74K LT1 is near full bolt with the following mods:
AS&M cold air induction with K&N filter
Borla stainless steel adjustable catback
RK sport 1/34 mid length headers
Bullet muffler in place of catalytic converter
Elite spark plugs OVC wires
NGK iridium plugs
Trick flow elbow
52MM throttle body
Throttle body air diverter
Comp Cams 1.6 roller rockers
LT4 valve springs and retainers
March underdrive pulley w/ alt. pulley
4.10 Ring and pinion
1LE aluminum driveshaft
TB coolant bypass
160 degree t-stat
Madz28.com tune from Ion
LT4 knock module
I swear the Zaino helped too
The Superflo STP corrected numbers were:
301.5 RWHP @ 5400 RPM
326.7 RWTQ @ 4100 RPM
It is obvious from the results and the dark smoke that the A/F ratio is rich at 12-12.4
I might be losing some power here.
All in all I am very happy with the results.
What do you guys think I can get in the 1/4 mile?
NGK iridium plugs
Trick flow elbow
52MM throttle body
TB coolant bypass
160 degree t-stat
LT4 knock module
Re: My LT1 dyno results...Not too shabby, I think.
Congrats on the numbers. I think with those numbers you should run mid 13's with street tires. Put a tire on it and low 13's.
However, not trying to put a damper on things, but with a 6-speed I think your numbers are a bit low... I think that your mods should put you at around 315-325 rwhp. You still have the stock 10-bolt right? If you didn't have 1.6 RR I'd say your numbers are pretty close. It doesn't appear that you were on a dynojet though, so that could account for the lower numbers. The real test will be to see what it does at the track.
Hurry up and let us know what she does!
The 4.10's rock. Its a whole new car with so much more out of the hole power its hard to put into words. I highly reccomend this to the M6 guys out there.
This dyno was not a Dynojet, it was a Superflow.
I have not heard anything positive or negative about the this dyno. Maybe someone here can comment on it.
There was also a 2003 Z06 vette that put down 355 RWTQ, I did not catch the HP.
Originally Posted by BeaversTA
Those are not SAE#'s are they?
Maybe someone can educate me on what all the numbers reall say.
It was my understanding that these were corrected numbers for temps, pressures & altitude.
Originally Posted by kgkern01
I would say that would probably be pretty close, since he is running mid-length headers as opposed to the typical LT's could account for being a few HP off, as well as the A/F ratio. Lean it out a little bit and should gain a few more HP.
Location: Austin, TX or Texas State University at San Marcos
Yeah lean it out to about 13:1 and you will see 10-15 rwhp.... Still pretty good numbers though. Looks like the 1.6rr's pushed ya over the edge
wrd1972, 355 rwt is about right for a stock 03 Z06 with a tune so I imagine your numbers are pretty accurate. Also, I feel exactly the same way about my 4.11's as you do with your 4.10's. The car feels MUCH more alive. 5th gear is actually useable lol.
Numbers are pretty good. If you get it tuned, you might squeeze some more out of her. I had similar numbers when my car was a bolt-on car and I only had 96 dual cat slp shorties and full emissions! Best et I had was a 13.12 at 107 and change with a 1.9ish 60ft on bf goodrich drags. Gives you an idea what you're car is cappable of.
