my passenger side fog light went dead!!!
Old 07-02-2003 | 10:26 AM
cridom's Avatar
Angry my passenger side fog light went dead!!!
what can i do to fix this?
show i replace bulb or fuse or fog light?
help
thansk
Old 07-02-2003 | 10:31 AM
MTL_Z28's Avatar
I have the same problem.
Old 07-02-2003 | 10:51 AM
Indy93Z28's Avatar
It's probably just the bulb.
Old 07-02-2003 | 11:04 AM
Will84's Avatar
bulb
Old 07-02-2003 | 11:28 AM
1msfyter's Avatar
Reemove them, save the weight . The fog lights are useless.
I have the 1LE grills.
http://www.bealer.org/Vents.jpg
Old 07-02-2003 | 03:02 PM
MeefZ28's Avatar
If the housing is still intact, just replace the bulb.
Be warned, it is a royal PITA. Here's a good install guide to do it thought. good luck,
http://www.bfranker.badz28.com/fbody/fogs.htm
Old 07-02-2003 | 03:08 PM
Serial Thriller's Avatar
I've replaced my driver's side fog light bulb quite a few times. I think the housing is cracked and allowing moisture in, which kills the bulb prematurely.
Old 07-04-2003 | 03:37 PM
Zack's Avatar
would the same process be used for Trans Am fog lights?
Jlo
02-03-2015 09:41 PM
siguy
11-27-2014 10:07 AM
07-04-2005 05:00 PM
Quick Reply: my passenger side fog light went dead!!!
