My Tach Is Off!!
My Tach Is Off!!
I asked this question once before... no answer, so I did a search... nothing
My idle reads 1000 when i'm at 850. My dyno pull was to 5450 when my tach read 5800. I NEED to fix this PLEASE
Re: My Tach Is Off!!
Nothing can be done in the PCM. That is not where the fault is. It is the conversion from digital to analog at the gauge and the inaccuracies of the movement of the gauge, itself. If it was off the same amount over the whole rpm range, you could just reposition the needle.
When my car was an M6 with the factory 800rpm idle speed, I got the same readings you are seeing. My solution....
http://cjcfo.fbody.com/members/injun.../DCP03456a.jpg
But Injuneer... how much did all that cost? Man that looks expensive!! haha
I just want my RPM tach fixed... thats all. I guess the speedometer is alright... haven't noticed anything foolish on it.
I would just shift at around 6200... that should put you at 5800ish. Aftermarket tachs are not cheap! An alternative to a tach is a simple shift light. Instead of reading the tach, you just look for the light.
