NA or FI ????
#16
Get a VRE or Golen Shortblock set up for boost
http://www.golenengineservice.com/ht...rt_blocks.html
VRE............
RE 383ci Racer Series Short Block
pic
Description:
Our 383ci LT1/4 Short Blocks are for the enthusiast that demands more from their engine. This engine can easily support 600rwhp in power adder applications with a shelf stock piston. Be sure to contact a member of the VRE staff for your specific application.
Specs:
* Compstar 3.750" Stroke 4340 Crankshaft
* Compstar 6.000" H-Beam Rods
* Mahle -5cc Flat Top Pistons
* Mahle Rings
* Clevite Rod Bearings
* Clevite Main Bearings
* Clevite Cam Bearings
* ARP Main Studs
* Balance Rotating Assembly
* Fully Machine Block w/ Deck Plates
* Blueprint and Assemble
Options:
* Fel-Pro Head Gaskets $39.99ea
* Cloyes Timing Set $90.99
* Comp Cams Camshaft $245.99
* BBK 58mm Throttle Body $309.99
* Piston Coating on Skirts and Tops $315
* ATI Harmonic Balancer $379.99
* ARP Head Studs $124.99
* Upgrade to Callies Dragonslayer Crankshaft $500
* Upgrade to Diamnd Pistons and Rings $250.00
Price:
* $3650.00 *No Block Core Required*
Bolt a set of LE1/2 or Ai heads, intake/cam package, stir in 10lbs of boost.....DONE.
David
VRE............
pic
Description:
Specs:
* Mahle Rings
* ARP Main Studs
Options:
Price:
David
#17
Plus all the odds and ends you need....It won't be as cheap as you think. As long as you realize it ahead of time you will be fine.
I built a el-cheapo engine....eagle rotating assym, $1500 heads about $1200 in the valve train. Cometics, machine work...did it as cheap as I could ( I'm on a limited budget) And it was not still cheap.
And I know it probly won't last either, I wish I would have done something else and spent more money
#18
ughhhh lol all this money lol... i was lookin to spend around 10k total...guess its not possible ..... maybe ill just build a motor closer to 430-450 whp and worry about boltin the charger on later ..... so many variables to think about..... i just dont wanna make a mistake its alot of money to be messin aorund with
#20
You CAN do it for that, but you will have to shop around and buy ALL used stuff.
See ya in the for sale section
David
#22
VRE............
pic
Description:
Specs:
* Mahle Rings
* ARP Main Studs
Options:
Price:
David
VRE............
pic
Description:
Specs:
* Mahle Rings
* ARP Main Studs
Options:
Price:
David
you dont even have to go that crazy for a shortblock
My shortblock will be about 1500 and it'll hold up to boost.
I can get a forged shortblock locally thats going to be the same as that VRE for 2k.....
Check your local machine shops for prices
plan on about 2500 for a good topend
If you are going boost...theres no need to immediately upgrade the top end. except the cam.
