Need Coil bracket bolt and/or stud part numbers...
I am looking for the part numbers or sizes for the bolts/studs/nuts that hold the coil bracket to the driver side head. It looks as if its 2 studs and 2 nuts. I thought i ordered them through GM but they gave me what appears to be the wrong studs because they are WAYYY to long...shoebox, can you provide a part number and or size for the stud/nuts and confirm that both left and right side of the coil bracket are for studs and nuts....i belive the nuts are used for connecting grounds to the car....Thanks alot...
Re: Need Coil bracket bolt and/or stud part numbers...
After abit more indepth searching, I found what I was looking for. The left hole for the coil/ICM bracket is a BOLT, NOT a stud. That bolt part number is: 9424338 The right hole is for a STUD this stud part number is: 14057279 and for all of you wondering the EVAP retainer part number (goes on with the BOLT on the left side of the coil/icm bracket is part number: 10186192
So in order to fasten the COIL/ICM bracket to the driver side head you need PN: 9424338 & 14057279
Hope this helps everyone in the future...
I agree with you there Shoebox....mine is the same...just like the bottom alterntor to accessory bracket bolt says its a 3.5" galvinizes bolt when on most of our cars its a 4-5" bolt with a flanged nut at the other end.
