need electrical help please!!!!!!!!!!!
The owner's manual says it powers these things:
Fuse 6 - Coolant Fan Relays; EVAP
Canister Purge Solenoid; Exhaust
Gas Recirculation; Low Coolant
Relay; Reverse Lockout Solenoid
( 10 Amp.)
Your problem could be in any one of those items. If it only blows when the fans try to come on, then it might be a faulty relay. If it blows as soon as you turn the key ON, then try unplugging those items until it does not blow. If everything is unplugged and it still blows, you probably have wire grounded out that you will have to find.
( 10 Amp.)
tdigger9899
09-07-2015 10:56 AM
