need help
need help
im looking at buying a 94 z just for the motor for my t/a. the motor is seriously build but some say the power was fine and it didnt need to be splayed others say it should have on ls1tech. i was gonna get a few more opinions. after motor was build it was driven without a tune and dyno'ed 429rwhp. well after tune is dyno'ed 490rwhp. then on his way home it spun a bearing and lost oil pressure. here the specs
ENGINE
short block 385 cid .040 over with a 3.75 stroke crankshaft
3.75" stroke steel crankshaft / internally balanced
SRP forged Pistons .040 over / sealed power rings
6" Eagle H Beam rods
Canton Oil Pan
Blueprinted and flow tested Oil Pump with canton pickup
ARP main studs
heads, valve-train, intake 2.0 intalke 1.57 exhaust REV stainless valves
ported cylinder heads
Titanium retainers
Comp Cams Pro Magnum 1.6R Rockers
Comp Hi Tech Pushrods 5/16
Manley Guide Plates
Comp Solid Lifters
ARP Pro Series Lifter studs 7/16 -7/16
COMP Solid Roller 248-254 .614-.622 lift with 1.6rr 112LS - 4'advanced
Arp head bolts
ARP main studs
ARP Cam Bolts
Ported intake manifold
Holley 58mm throttle body
30lb / hour injectors
Custom tuned computer by Atlanta Chassis Dyno
Arp balance bolt
ARP headers studs 12 pt.
Hooker Super competition headers - ceramic coated
Mufflex 4inch exhaust system
MSD 6AL ignition
MSD Blaster coil
Meziere Electric Water Pump!
ENGINE
Canton Oil Pan
ARP main studs
Titanium retainers
Manley Guide Plates
Comp Solid Lifters
Arp head bolts
ARP main studs
ARP Cam Bolts
Arp balance bolt
MSD 6AL ignition
MSD Blaster coil
